Cracked Vinyl Siding Repair in 5 Steps
Zip Tool
Pry Bar
PVC Cleaner
Scrap Vinyl
Glue
PVC Cement
Hammer
Nails
Vinyl siding repair is something that can easily be done with the proper tools and know how. You will find that it is important for you to be able to repair vinyl siding as soon as you notice any cracks. The cracks can easily become bigger if left unattended. If the cracks become too large, then you will need to end up replacing the entire piece of siding as opposed to fixing just a crack.
Materials Needed:
Zip Tool
Pry Bar
PVC Cleaner
Scrap Vinyl
Glue
PVC Cement
Hammer
Nails
Step 1 – Zip Tool
The first thing that you are going to have to do is get out your zip tool. You will be able to find this tool at any siding supplier. You will insert this tool underneath the bottom edge of the overlapping section of your siding. You will pull down on it as you slide your tool horizontal. You will then need to get out your pry bar or a hammer and remove all of the nails.
Step 2 – Clean
Once you have removed the cracked section, make sure that you thoroughly clean the back of your panel. Use a PVC cleaner to do this. Look at the crack or tear and cut a piece of scrap vinyl big enough to cover the tear. It is a good idea for you to measure the area first to make sure that it is the right size. You will need to make sure that you have completely covered the area and then some. Not covering enough of the area will eventually cause the crack to get bigger.
Step 3 – Glue
Once you have the scrap in place, you will need to glue it. Make sure that the finished side is down. The prepared surface will need to be on the PVC cement part.
Step 4 – Nail
The repaired panel is now ready to be nailed into place. In order to do this, you will need to get the side relocked by pulling along the bottom edge of the siding that overlaps. Use your zip tool to do this. As you are doing this with one hand, use the other hand to press the edge of your top panel up over the ridge of the bottom piece.
Step 5 – Hints and Tips
If you are unable to find any scrap vinyl, then this is something that you will be able to work around. Find an old laundry detergent bottle or a plastic milk jug that you are no longer using. Cut out a piece of it big enough for the crack. If you have a shallow crack, then you will be able to repair it without having to remove any of the siding. You will simply need to lift up one side of the crack with a toothpick and apply some adhesive to it. Press it closed after you have done this. As previously mentioned, make sure that the replacement patch is bigger than the crack. You will need to make it at least a full inch longer than the crack that you are covering.
Step 1 – Zip Tool
Step 2 – Clean
Step 3 – Glue
Step 4 – Nail
