Deciding Where to Install Your Gas Water Heater: Pros and Cons Deciding Where to Install Your Gas Water Heater: Pros and Cons
To install gas water heater, there are several things that you will need to keep in mind. The placement of a gas water heater is one of the most important things that you will have to think about. Where you place it will have a lot to do with what is going to be the most convenient and safe for you. Before you even bring home a gas water heater, you will first need to decide where it is that you will want it to go in your home.
Basements
Basements are a good place for a water heater. The appliance will be out of the way, in a large area to allow for upkeep and repairs, and easy to access. The downside is the existing gas line may not run in to the basement. For basement installations, gas and water lines may need to be added. Check around your basement and see if existing lines are there. If so, this can be an ideal place for your water heater.
Closets
Another area to consider placing a water heater is a closet that isn't used. This will conceal the water heater and allow you to keep it on the ground floor. Closets can be cramped places to work though, and repairs can be tricky. It also may not be a good idea if it's in a part of the house that isn't frequented, as leaks could go unnoticed until lots of damage has already occurred.
Cabinets
A popular option for smaller homes is utilizing small cabinets for water heater placement. The cabinet will conceal the heater, and for half-size models, can create some extra storage space above the enclosure. The problem with this is that maintenance and upkeep may require you to remove the water heater all together if it needs to be worked on. There will be almost no room to access the heater. For rental properties that have maintenance teams, this may not be a problem. For the average home owner, this can create a problem later down the road.
Other Considerations
Something for you to think about is placing your gas water heater near an existing gas line outlet. This will make installation so much easier, not to mention cheaper. If you happen to have your gas water heater in a location that does not have a gas line that already exists, then you will need to get a professional to install one for you. This is something that is going to end up costing much more money than if you were able to find a place for it where there is already an outlet. This way, whenever you install it, all you will have to do is simply hook it up. Just make sure that the outlet is up to code and will be able to handle the gas water heater that you are installing into it.
You will run into the same problems with water lines. You will need to make sure that your gas water heater is also near existing water lines. If it is not, then you will once again have to have a professional come out and install it for you. It is a good idea to have your gas water heater near at least one of these lines if not both. Having to have a professional come out for both is going to probably end up costing you more than you paid for the heater itself.
