Designing a Vegetable Garden Layout Designing a Vegetable Garden Layout
If you are planning to start a garden, particularly a vegetable garden, you should definitely look into creating a vegetable garden layout. In doing this, you will save yourself time and money in the long run by knowing how to plant them correctly. Keep reading for some tips on how to create your own vegetable garden layout.
Step One - Choose the Right Vegetables
The key to planning a perfect vegetable garden for you and your family is to figure out exactly what vegetables you eat the most and how often you eat them. It doesn’t make sense to grow vegetables you won’t feel like using, so be sure to ask your family what foods and recipes they love the most. Look through your recipe books, specifically the recipes you make the most, and write down the most commonly used vegetables. You can also write down common herbs you see and plant them right in the front of your vegetable garden for easy access. You should also think about how many of each vegetable you will need so you can figure out how much to grow. You can even time your vegetables to mature at the same time in order to combine them into a recipe.
Step Two - Do the Research
For the most important part of planning your vegetable garden layout, you will need to visit your local library or use the internet. Researching the vegetables you want to grow is essential because you will save yourself from inconvenience and wasted time. If you skip the research, you will risk hindering the growth and quality of your vegetables. For each plant, you should find out how high it will grow, how long it takes to mature, which plants grow better when planted next to each other, how much light or shade it requires, how much water it requires, what its soil requirements are, and how much each plant will produce. This information is essential in planning out the many elements that come into play when growing vegetables. When you are done, measure the location of your garden so you know how much space you will have to work with.
Step Three - Make Final Decisions
Go through your list of vegetables and the research you have required to analyze which plants will make it in your garden and which ones you should avoid. If a plant you are dying to grow does not work well in your climate, research into ways to grow it indoors, whether naturally or hydroponically. If you notice that some of your vegetables require more sun than others, maybe you should break your garden up into two or three different locations. Do the math so you know how much space your plants will require and how much you can give them.
Step Five - Draw your Layout
The most important aspect of creating your layout is to be sure you organize well. Use a pencial and paper or your computer to create an actual layout. Place the shortest plants in the front and the tallest in the back for easy access and consistent airflow. Also, you should research what plants grow well together and try to locate them near each other.
