Designing Custom Beveled Glass Doors Designing Custom Beveled Glass Doors
Beveled glass doors can be a lot of fun when it comes to designing a custom make for you. You will find that there are several different paths that you can take to help to make it your own unique and personal style. It at first can seem very overwhelming when it comes to trying to narrow down the exact look and style that you want. Knowing what your options are will certainly help in getting the best possible beveled glass door for your home.
Choosing Designs
It can be difficult at first to try to find a design that works best for you and your home. It is important to keep your décor in mind. Are you planning on changing your décor frequently? If this is the case then it is a good idea to get a design that is not going to be specific to your current décor. You do not want to have to always be changing your doors to keep up with your ever changing décor.
It is important that you shop around and get as many catalogs as possible. This will help you to get a good idea on what type of design you want. Even if you do not choose a design right out of the catalog, you may find yourself inspired to creating your very own design.
Benefits of Beveled Glass Doors
There are several reasons to go with these types of doors over a typical door. If you ever plan on selling your home, you will have no trouble doing so with a beautiful entrance. It will immediately up the value of your home and help you to stand out among your neighbors.
You can choose between stained or clear glass. While with clear glass you will be able to easily see outside and allow additional sunlight in, stained glass also has its perks. You will find that stained glass will be able to provide you with extra privacy as well as keep you from having to worry about blinds or curtains. You will also not have to worry as much about dusting and keeping it clean.
Additional Tips
If your home is currently under construction and you have made the decision that you will want to eventually or even immediately install a beveled glass door, alert the constructor as soon as possible. Measurements will need to be taken so that you will be able to make sure that the door that you choose will fit and will look good in the area that it is going into.
Usually, you will have to add transom and leaded glass side lights. A lot of constructors will not be willing to do the extra work or put the extra money into it. This will leave your doorway looking unfinished. This is an important step to remember whenever you are measuring for your beveled glass door.
There are a lot of factors that you will have to consider whenever you are deciding on a beveled glass door. It is important that you are aware of all of the decisions and have made them before you begin to seriously shop for one.
