DIY Soundproof Insulation Tips DIY Soundproof Insulation Tips
Soundproof insulation is not something which is only used by professional people in the music and recording fields. With improved technological advances, and relatively much smaller yet powerful recording equipment, many people are opting to make a home recording studio in one of the rooms of their home, or in a garage or basement. Needless to be said, such a venture will produce high sounds, which might bug the relatives and even the neighbours. Hence it is important to properly soundproof the particular room so as to avoid being a nuisance. There is no need to spend a lot of money on sound isolation enclosures and related professional accessories. Here are a few tips on how you can do the job yourself, with basic items.
Tip 1 - Use Carpets
Carpets can greatly muffle the sounds produced. However, do not restrain yourself to using only carpets on the floor. It is a practical and effective way to insulate sounds, by attaching carpets all over the walls. Carpets serve as a good foundation for sound insulation in fact.
Tip 2 - Use Foam
You can then attach layers of foam upon the carpeting coating. Make sure to fasten it well and to avoid any overlapping. If the foam is rather thick, it may be best to use nails rather than glue. You may deem it fit to add more than just one layer of foam to manage to insulate the sounds better.
Tip 3 - Use Vinyl Strips
The room will inevitably have doors, windows and ventilators. In these areas it is best to cover the edges with vinyl strips.
