Do I Need an Oxygen Sensor for My Propane Fireplace?
In order for your propane fireplace system to work correctly, you will definitely need either an electronic oxygen sensor at the input or you will have to be extraordinarily talented in setting up the input controls for your fireplace. Although propane systems look simple – a bottle of propane, a hoses, and a coupling – ensuring the right height and right usage rate takes more than just a steady hand on the relief valve. It does require the exact nature that an oxygen sensor system offers you. An oxygen sensor will also help ensure that there's no buildup of carbon monoxide.
