Do Natural Sponges Scratch Travertine Floor Tile? Do Natural Sponges Scratch Travertine Floor Tile?
If you have travertine floor tile, you may be looking for an effective way to clean it without damaging it. The finish on travertine is very particular, so you can only use certain things on it in order to prevent damage. One of the products that you should avoid using on travertine is a natural sponge, which may have trace amounts of sand in it. If the sand is not thoroughly removed from the sponge and you use it to clean your travertine tile, there is a good chance that it could cause scratches in the surface.
