Do You Need to Buy an Air Compressor? Do You Need to Buy an Air Compressor?
An air compressor provides a way of powering tools for use on both auto and the home instead of using electricity. This can include sanders, cutting tools or air-operated wrenches such as ratchets or impact guns. Read on to learn more about these tools and whether or not you should buy one for home use.
Working On The House
If you’re doing a full remodel on your house, an air compressor and pneumatic tools can save you a lot of time and effort. A pneumatic chisel can quickly take out on old fittings while a pneumatic nailer can make framing, roofing, and drywalling significantly easier. You can buy many pneumatic tools in a kit these days so you should be able to get most of a full range of tools that can be used when you work on a home.
For most home jobs, you can buy a small, portable air compressor. Because they’re oil-free, you don’t have to worry about the piston seizing up on you. Generally, this can be an expensive repair. To use an oil-free compressor, you simply plug in the compressor and it will start working automatically.
Working On The Car
Anyone who’s tried to rotate tires at home will know what a long and arduous task it can be. Manual tire changing leaves the arms tired after using a wrench for what seems like hours. With an air compressor and a socket wrench, it just takes seconds to remove a tire.
If you’re a shade tree mechanic, an air compressor is a very worthwhile investment. You’ll complete jobs sooner and with far less frustration. Virtually all work on a car will go faster by using pneumatic tools and an air compressor.
Buying Versus Renting
You can easily rent an air compressor and if it’s something you’re only likely to use once or twice a year, this is the best course of action for you. However, if you revel in DIY, do several jobs a month or are planning additions or remodels, buying an air compressor can be money well spent.
Other Uses
Compressed air doesn’t just power tools. You can use it for many other things such as cleaning out ducts or blowing sawdust from wood you’ve just cut and sanded. These might seem like small things but an air compressor will do the job very efficiently and quickly.
Cost
Cost has to be an important factor when you’re wondering if you need an air compressor. If you have the money, it’s not a big problem. For those on a budget, however, it’s a big decision to make. Be honest about the amount of work you do in your home and on your car before you decide whether you can afford an air compressor. Don’t compromise by buying one that’s too small for your needs because it won’t do a good job for you and could soon burn out.
If your work level at home is reasonably extensive, you really should consider having air compressor in your garage or workshop to make life a lot easier.
