Does Saltillo tile sealer change the color of Saltillo tile?
Saltillo tile sealer is used to seal and protect Saltillo tiles from damage and water penetration. There are many types of sealers and stain/sealer combinations you can use.
  • Saltillo tile is very brittle and porous so it must be sealed often. Sealers can help protect from the fading of color, especially if used outdoors.
  • All Saltillo tile should be sealed on a regular basis to protect it from stains.
  • Saltillo tile sealer may darken the tile slightly, even when a clear sealer is used. This darkening isn't permanent and will fade as the sealer is worn off the tiles and absorbed into the tiles.
