Does Wide Plank Laminate Flooring Last Longer Than Thin Plank? Does Wide Plank Laminate Flooring Last Longer Than Thin Plank?
Wide plank laminate flooring should not last any longer than an identical piece of laminate in a thin plank. In fact, thin plank might have an advantage when it comes to lasting longer because it is more compact and dense. With a wider plank, the surface of the material is spread out over a wider area. When you step on it, the weight coulld potentially bend the plank in the middle. The longevity of the laminate really depends on the surface layer and what type of laminate you are purchasing. A better surface layer will make it last longer.
