Does Wide Plank Laminate Flooring Take Less Time to Install? Does Wide Plank Laminate Flooring Take Less Time to Install?
Wide plank laminate flooring will take less time to install than traditional laminate. This is because wide plank laminate is made up of fewer pieces. Since the laminate boards are wider, each board will cover more of the flooring area. This means fewer reasons to bend over and tap the boards together. You will also have to make fewer cuts in the laminate, which traditionally takes quite a bit of time. Laminate is generally one of the fastest types of flooring to install anyway, and when you get the wide plank variety, it will go even faster.
