Drain Maintenance Before Overflowing Toilet
To keep from having an overflowing toilet you should spend some time with basic drain maintenance. This will ensure that you do not have an emergency in the middle of the night when you might not find the plunger in time. In the event of an overflowing toilet, the floors, and the ceiling of the room underneath, can be ruined from the water. It is better to take the time to maintain the drain than spend the money to fix the repairs.
A Mixed Schedule
A lot of maintenance work is done on a home during the spring season. This is also a good time to schedule the routine maintenance of your drainage system. However, there are also some other tasks that can be performed with just a few minutes of your time that will ensure the drain is clear of any type of build up.
Flush with Hot Water
One of the ways that you can keep clogs from forming is to flush the toilet drain with some hot water. Boil some water in a large pan. Pour it into the bowl of the toilet and flush it. The water will rush through the drains and clean out any deposits within the pipes. You should do this at least every other week.
Use an Enzymatic Cleaner
There are plenty of cleaners that will help you keep your drains clean and odor free. An enzymatic cleaner, like Bi-O-Kleen, should be used on a monthly basis. The enzymes contained in the cleaner will eat away at any organic matter and deodorize the pipes.
Clean Toilet Drain with Vinegar and Baking Soda
An overflowing toilet can be a disaster. This is especially true if you are not home while the toilet is running and overflowing. The amount of damage that can be caused is tremendous and costly. Besides performing the previous maintenance projects you should use some vinegar and baking soda. At least twice a year flush the toilet drain with some hot water. Follow that up with a 1/2 cup of vinegar and then 1/2 cup of baking soda.
Snake Drain Every Six Months
Besides running hot water, cleaners, and vinegar down the drain on a consistent basis you should also use a drain snake. A snake is a great tool that can be fed down the drain. If it meets with any type of blockage you twist it with the handle and it drills into the clog. Use the drain snake every six months to make sure the pipes are clean.
Keep Drain Vents Clean
Another aspect of a toilet drain that many people forget about is the vent. While you are performing maintenance to the toilet drain you should also check out the vent that goes to the roof. This vent, if clogged, will have a big impact on the way that the toilet drain works. If it is clogged, then the drain will not work properly causing the toilet to overflow. Flush the vent periodically with a hose to ensure that all debris is washed down and not building up in the vent. You can also send a drain snake down the vent if you do find a clog.
