Drainage Pipe Installation Mistakes to Avoid Drainage Pipe Installation Mistakes to Avoid
Installing drainage pipe can be a challenging, though necessary process to ensure the health of your home. If you’re in need of a drainage pipe, but do not have one, you could be risking things such as damage to the foundation of your home, rotting your garden or even providing a place for mosquitoes to nest and mate. Considering the severity of all of these problems, it is well worth the time to install a drainage pipe on your property if one is necessary. Here are some common mistakes to avoid, so that you will be ready to re-route your water to a safer, more desirable spot.
Mistake #1: Lack of Planning
The best way to ensure that your drainage pipe installation goes off without a hitch is to make sure you plan the process out from every imaginable angle, making sure not to overlook even the slightest of details. One of the most overlooked, yet crucial details is where the water is drained to. You need to make sure not to install your drain too close to the foundation of your home. Make sure the end of your drain is at least 6 feet away from your foundation. Overlooking this step could result in rotting your home's foundation, which will ultimately lead to much bigger problems in the future.
Mistake #2: Avoiding Utilities
Make sure you know exactly where you are digging. Get in contact with your local utilities department about any possible cables that may run underground on your property. Hitting these cables could cause major problems that could possibly result in electrocution, the power going out or worse. You will also more than likely be responsible for covering the cost of any repairs that need to be made because of any improperly planned digging you’ve done.
Mistake #3: Inconsistent Pipe Levels
Another common mistake you should avoid is to install your pipe at inconsistent levels. You don’t want any dips or portions of the drain that will have to travel uphill, even at the slightest grade. This will lead to slow water drainage and possible backups, breaks and pooling. You also want to make sure there are no sharp turns in the design of your drainage system, as this will cause problems regarding the proper flow of your water.
Remembering these mistakes and avoiding them when the time comes could save you a lot of money, time and hardship. If you install a drainage system improperly, not only will you not fix the root problem, but you will also potentially create more for yourself in the long run. Keeping these things in mind should allow you to successfully install a drainage system.
