Drapery: A Removable, Stylish Alternative to Doors Drapery: A Removable, Stylish Alternative to Doors
Draperies are the new way of styling your home. They are commonly used as window dressings, but you can also use them as an alternative to doors. Draperies are available in different designs and colors. They are durable and long lasting.
Easy To Remove and Install
These stylish dressings can be removed and installed anytime without much hassle unlike doors. Installing doors can take up much of your time. You can install draperies on your own without the need of any professional help.
Privacy
Draperies cover your doors completely. They can provide the required privacy to your room just like doors. Draperies look very pretty when installed in your patio or balcony.
Insulation
Draperies are the best option for studio apartments and dorms. Draperies also provide adequate insulation. They can retain the heat in your room and give you a very cozy feeling. All you have to do is suspend them from rods or hooks and leave them to cover the area you want.
You can select from a wide range of colors and designs for your draperies. Look for draperies that complement your home décor.
