Easy and Fun Projects: Punch Needle Embroidery
needle point embroidery design with yarn and tool
What to do something crafty that isn't tedious? Want to create something charming, colorful, fun, and maybe even beautiful? Punch needle embroidery is a great way to get creative and make something new for your home.
You can also make gifts for others using this technique. Try some easy and fun projects using punch needle embroidery and see what you end up making.
What is Punch Needle Embroidery?
embroidery tools
Punch needle embroidery differs from other types of embroidery because you punch the yarn on the fabric, rather than pulling it through the fabric. The needle stays on the surface of the fabric, instead of going through it.
This creates a textured design that somewhat resembles carpeting. The resulting texture is extremely soft and has a great final look. Since you can create something in any color and any pattern you want, there is truly no limit to what you can do.
Once you know the techniques, you can create gifts for others and for yourself and never run out of different things to make.
punch embroidery needle
To get started, you needed the right supplies. First, you need the punch needle itself. This has a metal tip with a hole through it and resembles a standard needle. However, this needle has a space where the thread goes through it.
The needle also has a handle, which makes it easier to hold as you work. Punch needles are available in many different sizes based on length and thickness.
You need fabric to embroider on. Monks cloth is the most popular type of fabric used with punch needle embroidery You can get this fabric in all sorts of different varieties. If you'd rather you can always use linen or burlap.
Just remember that finer fabrics require finer thread. Embroidery floss is extremely fine. Yarn is perfect for thicker needles and more durable fabric.
Any standard embroidery hoop will work fine. This is the frame that holds your fabric steady while you embroider. Don't forget scissors, always a must in embroidery of all types.
You may also want some punch embroidery patterns. This is a good way to learn techniques and get comfortable. Remember that the design will be on the reverse because you always embroider the backside of the fabric.
Embroidery patterns are available at craft and sewing stores. Sometimes, you can also find simple embroidery patterns online. You can even learn how to make your own patterns so that eventually, you can create anything you want.
fuzzy needlepoint punch needle embroidery design
This embroidery technique is centuries old, though the more modern version of punch needle embroidery has only been around since the 1880s.
Modern versions of punch needle embroidery are derived from rug hooking techniques. That's why the finished embroidery creates a texture that is not unlike carpeting. Basically, you ake small loops.
To create something with punch needle embroidery, draw the pattern on the fabric. Stretch the fabric on the embroidery hoop or frame so that it is pulled very tight. Thread the needle with the color you want and begin filling in the pattern.
Once you get some practice and get used to the technique, you'll be amazed by everything you can create.
Start with simple patterns and basic shapes to get a feel for your technique and get used to creating this embroidery. Experiment with different threads and different needle thicknesses to see what you like working with.
Once you’re a little more comfortable with the tools and techniques, there are all sorts of things you can do. Look online to find free patterns. If you’re artistic, you can also draw your own patterns. The more your skills grow, the more complex your patterns can become.
Pillow covers, artwork, plush toys, clothing—there's a lot you can do with punch needle embroidery, once you start letting your creative juices flow. Learn this technique and get inspired. The more you do it, the more things you'll be able to make.
