Eco Friendly Living: 6 Green Roofing Options Eco Friendly Living: 6 Green Roofing Options
Green roofing has become a popular choice amongst homeowners. This reflects the increasing appreciation for eco-friendly alternatives in home construction. Green materials for roofing have high insulation properties. This improves energy efficiency in your home and lowers energy utilization. Durability is another aspect of green roofing. Roofing materials with high durability can last a lifetime and are also recyclable. This helps towards preservation of environmental resources. Eco-friendly roofing materials also have low maintenance requirements. Below are 6 environmentally friendly options you may want to consider for your roofing.
1 - Engineered Lumber
It is produced from wood fibers mixed with adhesives. Engineered lumber utilizes less wood than solid lumber. This helps to conserve wood resources. The manufacture process creates a product with great resilience. Engineered lumber does not deform or warp. Once installed, it lasts in good shape for several years. This contributes to higher durability for your roof. This is a great product to utilize for the framework of your roof.
2 - Clay and Slate Tiles
These tiles are non-toxic which guarantees higher safety in your home. Clay and slate tiles rate highly in energy efficiency. This helps to reduce energy utilization within your home, which contributes to environmental sustainability. The tiles encourage good circulation of air, both above and below. A cushion of air is created between the tiles and roof deck, which improves the insulation of your home. Clay and slate tiles are 100% recyclable. Slate tiles can remain in good shape for up to 100 years.
3 - Recycled Asphalt Shingles
These shingles are produced from reclaimed asphalt shingles. The shingles are ground into powder form, which is then used to create new shingles. They have high life expectancy, up to 50 years, which eliminates frequent replacement.
4 - Metal Roofs
Some of the oldest green roofing materials are made from steel, copper and aluminum. Metal roofs have an extremely high energy efficiency rating. They absorb less heat which helps to keep your home cooler. This is especially welcome in areas with a hot climate. Metal roofs are amongst the most durable. Many of them have a life span that exceeds 100 years. Once the roof is no longer desired, it can be recycled. This helps to conserve environmental resources.
5 - Rubber Roofing
This is made from recycled rubber. Rubber roofs have a high durability. Many manufacturers give a warranty of up to 50 years on rubber roofs. Once a rubber roof is properly installed, you need not plan for a replacement. Rubber roofs rate highly in energy efficiency. Due to their low maintenance requirements, fewer cleaning products are required to maintain your rubber roof. This means that less waste material from cleaning processes ends up in the environment.
6 - Structural Insulated Panels (SIPs)
These panels are produced from an insulating styrofoam contained between 2 plywood sheets. Oriented strand board may also be used in place of plywood. The panels help to improve the insulation properties of your home. This contributes to lower energy losses. Less roof framing is required when SIPs are utilized, which helps to conserve wood resources.
