Eco-Friendly Ways to Clean and Maintain a Drop Sink Eco-Friendly Ways to Clean and Maintain a Drop Sink
There are many ways to clean and maintain a drop sink without using toxic products that can pollute the waterways. Living green may not be easy to do for some because many people have been exposed to using toxic chemicals as cleaners for a long period of time. However, with constant practice and exercise, living green may not be as hard as it seems. Here are some ways to clean and maintain a drop sink without using any harmful chemicals.
Recycling Old Clothes
When cleaning a drop sink, it is not necessary to use a sponge treated with antibacterial properties. One of the best ways to living green is to recycle things commonly found in a home. Old clothes can serve as rags for cleaning drop sink surfaces. These clothes can also be used to wipe the wet surfaces dry after cleaning. Reusing old clothes as rags is a great way to cut on costs and save trees. Take note that paper towels that are usually used to wipe wet surfaces dry are made from trees.
Regular Cleaning
Maintaining the cleanliness of the drop sink is a sure way to avoid using abrasive and highly toxic cleaning agents. When water marks form on the surface of the drop sink, immediately clean it up using a damp cloth. Water marks can later become hard to remove when left unclean. Spills on the sink should also be cleaned at once. Rinse the spills quickly with water or use a damp cloth to remove residue left on the surface of the sink. Make sure that to clean the sink thoroughly at least once a week. Use a soft brush to dislodge dirt. For hard-to-remove stains and dirt, make use of warm water and a rag to clean them up. In addition, never flush solid debris down the drain because it may cause issues in the future. Make sure that the sink has a strainer installed.
Cleaning Stains
Stains in the drop sink can be removed using common household materials such as vinegar, baking soda, lemon juice, and salt. Some stains are very hard to clean using only damp cloth and soap. One of the most common cleaning agents used by eco-friendly people is vinegar. Vinegar is a low-strength acid that can effectively remove stains from sinks. Simply place vinegar in a spray bottle and spray it on the affected area. Allow the vinegar to sit on the stain for a while and use a damp cloth to wipe the stain afterwards. Another alternative to vinegar is lemon juice. Lemon juice contains citric acid that can dissolve hard water stains and other stains as well. Hard-to-remove stains can be cleaned using paste made by mixing lemon juice with salt or baking soda. Simply apply the paste on the stain and allow it to sit there for 30-minutes. Wash off the stain afterwards.
When opting to clean sinks, tubs and bowls in eco-friendly ways, it is wise to prepare the home with necessary eco-friendly cleaning materials just in case they will be needed.
