Electric Edger vs Gas Edger Electric Edger vs Gas Edger
Both the gas and electric edger can be effective tools, depending on your situation. While both of these types of edgers have some benefits associated with them, both of them also have some drawbacks as well. Here are a few things to consider about electric and gas edgers.
Convenience
When it comes to convenience, the electric edger is going to be superior in this area. An electric edger will be ready to go when you are ready. You will simply have to unplug it from the wall and press a button to initiate the engine. You can then immediately start edging your lawn.
With a gas edger, this is not going to be the case. You will have to make sure that gas is in the edger, and then you are going to have to start the engine. Depending on the model, you may have to pull on the cord several times to get it started. This can be very inconvenient and can add a lot of time to your project.
Ongoing Costs
Something else that you will need to consider is the ongoing costs of both models. With an electric edger, you are going to plug it into a standard wall outlet to charge. Most of the time, it will charge up overnight and you will be ready to use it the next day. The cost of the electric power to charge the edger is going to be very minimal. With a gas edger, you are going to have to continue to purchase gas. While this is not going to be a huge expense, it will add up over time.
Power
Another factor that should be considered is the power of both types of edger. In the vast majority of cases, a gas model is going to be much more powerful than an electric one. Therefore, you are going to be able to finish your job quicker and be much more efficient. It is going to cut through the grass powerfully and quickly when compared to an electric model. This might actually improve your results and make your yard look better with minimal work. If you have an electric model, you may have to go back over the same area more than once in order to achieve the look that you are going for.
Availability
You may also need to think about the availability of each type of edger. With a gas edger, you are going to be able to use it whenever you want. As long as you can get it started by pulling on the cord, you are going to be able to do your work. This may not be the case with an electric model. You are going to have to make sure that it is fully charged before you can work. Therefore, if you accidentally forgot to plug it in, it may not be ready to complete the job.
