Energy-Saving Options for an Exhaust Fan
There are several energy saving options available for an exhaust fan. They include low energy exhaust fans that are designed to operate at a lower wattage, and in many cases are quieter than older fans. These new low energy exhaust fans can be installed during new construction or as part of the remodel of a kitchen or bathroom.
Low Energy Exhaust Fans
Low energy exhaust fans operate at a more efficient rate than those fans with a higher wattage. They are designed to operate between 13 to 35 watts. Although they operate at a lower wattage than the older exhaust fans, they move air flow more efficiently. This increased efficiency means that the exhaust fan is designed to work under a lower power setting and be more efficient than an older exhaust fan.
Air Flow Settings
Air flow settings on the exhaust fan can be changed in order to save energy. Traditional lower settings have been designed to work efficiently to remove moisture and odors from the kitchen or bath. This removal, which is the purpose of an exhaust fan, can be done in a lower setting mode.
Replacing Older Exhaust Fans
Replacing an older exhaust fan with a more energy efficient and newer exhaust fan helps reduce your electric bill. The energy savings derived from the installation of the energy saver exhaust fan will translate in cost savings for you and your home. It will increase the efficiency of your fans operation and also help you learn how to use energy in a more efficient way for all of your home needs.
Determining Energy Efficiency of Current Exhaust Fan
When you want to replace the exhaust fan in your kitchen or bath you should make a determination of the current energy that is being used. A local energy company can have an individual come out and perform an energy audit that will give you a sense of the amount of energy an appliance uses in relationship to its efficiency. This process will help you find and acquire the best energy saving exhaust fan that meets the needs of your home.
With the energy efficiency information that you receive from the energy audit, you can take the information to compare your needs with the different types of energy savings exhaust fans that are available for sale. Look for low wattage settings that will help to increase the efficiency of the exhaust fan, as well as air flow settings that work best to remove odors and moisture in the most efficient manner.
