Epoxy Stone Driveway vs Concrete Driveway
Both a concrete driveway and an epoxy stone driveway can provide you with some benefits. These are popular styles of driveways, so consider the following to determine which material will work best for your needs.
Looks
One of the biggest differences between these two types of materials is the look that each one provides. With concrete, you will get a flat surface that has a uniform color and appearance. With the epoxy stone, you will have a variety of colors and a varied appearance. Some people like the epoxy stone because it provides a little bit of variety.
Cost
If you are concerned about the cost, the concrete driveway will be less expensive. You can generally get concrete for around $2 or $3 per square foot. With the epoxy stone, you will have to pay somewhere between $5 and $9 per square foot. If you are doing a large driveway, this could be a substantial difference between the two materials.
Maintenance
You will also need to maintain the driveway regardless of which type you get. With epoxy stone, you have to make sure that it is regularlysealed or the stones could start to come apart.
