Exploring Hydrogen Fuel: Water Electrolysis Exploring Hydrogen Fuel: Water Electrolysis
Hydrogen fuel can come in many formats, but one great way to create hydrogen fuel is with water. Water is almost everywhere and is clean plus renewable. It is a fabulous and cheaper green option compared to other ones on the market. Here is some general info on what it is and how it works.
What Is It?
It is a process of water decaying in oxygen and hydrogen, which is caused by an electric current flowing through it. This creates the hydrogen fuel; by have the current flow from two metal plates. It can be used like most types of fuels, but make sure that the device supports hydrogen fuel. Otherwise, it could damage it and/or not run on it.
How Is It Created?
It is rather simple to create, but it may sound like a tough task to do for someone who never attempted to create it. Wires are connected to two metal plates that are heated and placed into the water. From there it will create negative electrodes and electrons will go into the water and turn the water into a type of hydrogen fuel. Of course, this will create a positive electrode that is an anode.
How Can I Use It?
Some automobiles are designed for using hydrogen fuel and other types of engines that support it. You will likely have either to build one or buy one that is made for that type of fuel. Most are not ready to sell in stores, so you will have to custom order one. Do not attempt to use this type of fuel in a regular automobile that uses fossil fuels, as this could ruin the engine and be very costly to repair the engine. You may also need to replace more parts or fuel tank if they were also damaged by using a non-fossil based fuel.
Can I Buy Water Electrolysis Hydrogen Fuel?
That will depend partly on where you live and how easily you have access to alternative based fuels. Not every town or city will have ready access to them, so you may have to create it yourself if needed. Though over time, you should be able to have ready access to it as it grows in popularity. Places that are big on the eco movement will likely either have it or soon enough will. So keep in eye out or call around locally for more info on if or where you can buy it.
How Green Is It?
With water being a renewable source and non-toxic to the Earth, it allows it to be used without emitting green house gases that are linked to global warming. As long as you have access to an electrical current and water, you will have access to the hydrogen water electrolysis fuel. Though it also does have it down sides, like being very flammable in it's own right. So all cautions should be taken when using or handling it. Like no smoking or firecrackers near it. It should also be stored in a safe place so that no animals or children get into it.
