Exterior Front Door Materials Consideration Exterior Front Door Materials Consideration
When you are choosing the type of material for your exterior front door, you will want to know a little about each one of your options. Here is some information that can help you to make a decision.
Metal
Metal doors are great because they are very sturdy and stable. You won't have any problems that you may find with a wooden door, such as shrinking, rotting, or the need to continually refinish it. A metal door can also provide you with a security that many other materials cannot. The only downside to having a metal door is that it doesn't always match the rest of the house in terms of style, especially if you have an older home. If you are updating your house and are going for a more modern look, then this is the best option for you. Try wrought iron doors for the best look.
Wood
Wood is the most traditional as well as the easiest to match with the style of your home. You have so many different options when it comes to wood. You can paint the wooden door to match your home or you can finish the wood to go from lighter to darker. There are also many different types of wood that can go along with almost any style you have. The downside to wood though is that while it is stable, since it is an exterior door, you will have to keep up with the maintenance. Sealing the door every year or so will be important, so when purchasing a wooden door, you will want to keep in mind the amount of time and money you can spend over the years working on it. Also, you need to keep in mind that wood tends to shrink as well as potentially mold or rot. You will need to take precautions for these issues too.
Wood does have some downsides, but do not be too put off by them. The majority of people have a wooden door of some kind. You just have to keep in mind that maintenance is key.
Fiberglass
If the beauty of wood is something that you love and want in your home, but you do not want to deal with the up keep, then fiberglass may be the right choice for you. This material is known for its decorative feel and is very affordable. If you have children, this type of door is great because it can be wiped down easily and hides scratches. The downside to this type of material for an exterior door is that it doesn't have the same natural feel as wood does, and it may not be as safe or sturdy as either wood or metal. However, if you want something beautiful as well as functional for a family, then fiberglass may be right for you.
When choosing the right door for you and your family, you will want to keep in mind the amount that you want to spend as well as the maintenance you will be willing to do as the years go by. Each one of these materials have pros and cons to them, but one will definitely fit your needs.
