Fiber Cement Shingles: Installation Tips Fiber Cement Shingles: Installation Tips
Fiber cement shingles are a popular choice for homes. They have been used for over 100 years. These shingles will generally last for decades and will come in a variety of colors. Here are a few things to keep in mind when you look at installing fiber cement shingles.
Color Choices
If you aren’t happy with the color options available, fiber cement shingles can be painted to the color you want. Just be sure to use a good quality outdoor paint. You can also make the shingles look new by simply washing them.
Starting the Installation
You will want to start by placing the shingles in a corner at the bottom and work your way out. This is the easiest way to get the shingles completely covering the surface.
Keeping It Level
As you work you will want to make sure you are placing the shingles perfectly level with the surface and one another.
Securing the Shingles
Most fiber cement shingles will have holes pre-drilled in the corners for your nails. You want to try to find a brand that has this, as hammering through fiber cement shingles can be a tough job. This will save a lot of work on your end.
