Fiberglass vs Vinyl Inground Pools Fiberglass vs Vinyl Inground Pools
Trying to decide between fiberglass and vinyl inground pools can be a very difficult decision. Both products can present you with several advantages and disadvantages associated with them. Here are a few things to consider about fiberglass and vinyl in ground pools.
Installing a vinyl pool is one of the most popular projects that many people undertake in their backyard. Vinyl presents you with several advantages over other types of pools. For one thing, it will usually cost you quite a bit less initially to get a vinyl pool. The material that makes up the vinyl pool is going to be cheaper than fiberglass. In addition to that, the labor to install the vinyl pool is not as difficult and therefore will be less expensive to you as well. When you combine these two factors, it could be thousands of dollars worth of savings on the front end.
In addition to the initial savings, you will also get the benefit of being able to walk on a more comfortable surface. Vinyl is smoother and softer than fiberglass or any other type of pool. Therefore, it is more comfortable underfoot and does not have that rough feeling that comes with other pool surfaces. Because of this smooth surface, there is less room for algae to grow. As a result, this can also save you money on the chemicals that are required to maintain the pool throughout the course of the swimming season. This can save you money over the course of the year as well.
Vinyl pools also allow you to be very creative when it comes to coming up with a shape for your pool. Vinyl is very flexible and therefore can be molded into any design or shape. This allows you to create a pool that is unlike the neighbors.
The main drawback to using a vinyl pool is durability. The liner for the vinyl pool will typically need to be replaced once every 10 years. The liner is often prone to tearing and fading as well.
Fiberglass Indoor Pools
Fiberglass is another popular material the pools are made of. One of the major advantages that fiberglass presents you with is the lower maintenance. Fiberglass requires very little maintenance when compared with vinyl and is more durable. Fiberglass pools can last many times longer than a vinyl pool.
While fiberglass pools will typically cost more on the front end, if you look at the long-term costs associated with owning a pool, they will usually come out less in the long run. Since you have to replace a vinyl liner once every 10 years or so, this substantially add to the cost of the pool. With fiberglass, you should not have to worry about any larger repairs like this.
One of the drawbacks of a fiberglass pool is that it cannot be customized into the variety of shapes and sizes that a vinyl pool could. Therefore, you have limited options when it comes to design.
