Finding the Perfect Mix for Concrete Countertops Finding the Perfect Mix for Concrete Countertops
Concrete countertops in kitchens and bathrooms are inexpensive to build and, with the proper preparation and pouring, can be beautiful additions to a home. Instead of using concrete solely for sidewalks and carports, mix your own concrete to pour a beautiful and unique countertop in your kitchen or room.
It's essential that you understand the different forms and colors available to you. An ideal concrete mix will be sturdy and firm, but also pleasing to the eye. If you don't have experience working with concrete in your own home, take the time to research and consider the variety of colors and styles that are available to you.
Choose a Color and Style For Your Mix
Concrete countertops may have a uniform style or a blend of colors and styles. A two-color countertop has a good combination of color variation and consistency, although it is important to carefully keep track of any color mixtures that you design so that you can remix them later on. Select your concrete color based upon the color of the walls and other fixtures around the countertop.
Coloring Your Concrete
Concrete coloring agents are available at most home improvement and outdoor supply stores. Color options are typically limited to shades of brown, black and red. However, shades of green, blue and other colors exist as well. Mix two or more pigments to create a unique concrete color that suits your countertop and your home. Experiment with sample concrete mixes to find the perfect color for your project.
Texturing Your Concrete
Generally, concrete should be 1 part cement, 2 parts sand and 3 parts gravel. When mixing, stir the ingredients together slowly while gradually adding water. To add texture to your concrete, mix additional varieties of concrete as well as sands or minerals. These supplies are also available at home improvement stores and can enhance the texture and appearance of your countertop. Because you'll trowel the surface of the concrete after pouring it, there's no need to be concerned about irregularities in a textured mix.
Ensure the Perfect Consistency of Your Concrete Mix
When mixing your concrete, make sure that you use water sparingly. A liquidy concrete mix will not fill a countertop form properly and will be difficult to work with. Your concrete mix should be doughy and semi-solid. Ideally, you will be able to pack the mix for your countertop into the form like clay. Mixing the concrete in the proper proportion will increase its durability and lifespan, and will also make the pouring process easier.
Concrete countertops can be beautiful additions to a home if built with care and attention to detail. Take the time and effort to select your concrete mix carefully, and ensure that the concrete is both a desirable color and texture for your kitchen or bathroom aesthetic.
