Fireplace Heat Exchanger: Considerable Benefits And Disadvantages
A fireplace heat exchanger is a great option to consider purchasing for your fireplace. While it does provide significant benefits for your fireplace, it also has some considerable disadvantages as well. Please read the information below as to the purpose of the exchanger, its benefits, and its disadvantages for a fireplace.
The Purpose of the Exchanger
The heat exchanger is a device which utilizes a network of piping encircling the fire within the fireplace. A fan is connected to the piping and heats the air around the fireplace as well as pushes it out into the room.
The Significant Benefits
Having a heat exchanger within a fireplace can improve the heating performance of the fireplace by around 10 percent. This can help to reduce your overall monthly heating expenses because the fireplace is more efficient at heating a room thanks to the exchanger.
The Considerable Disadvantages
Fireplace heat exchangers can be installed into an existing fireplace, but it is difficult and somewhat costly. Also, the pipes used in the heat exchanger are prone to soot buildup. Thus, the pipes must be regularly cleaned and maintained in order to prevent potential fire hazards.
