Five Basic Ways to Repair Your Garage Door Five Basic Ways to Repair Your Garage Door
There are several ways to repair a garage door if it is not functioning properly, and the majority of these methods are quite simple to perform if you have some basic repair knowledge. Hence, if your garage door is not closing all the way, or if it is not opening properly or even not operating at all, there are some things that you can check to troubleshoot it. Here are some basic ways to repair your garage door.
1. Noisy Garage Door
The first problem that you can easily solve is when a garage door makes a loud noise when opening up. Often, this happens when the micro-switch at the bottom of the garage door is not set properly. This switch is what tells the door to shut off, so if the door is jamming or making a loud noise when opening up, this switch is probably out of adjustment. All you have to do is either slide this switch up or slide it back to get it into the right position so that when the door hits it, it will stop before reaching the max travel on the tracks.
2. Set the Down Force
If your garage door is not reversing when hitting an obstacle, it can be dangerous, especially for small children. Hence, you have to make sure that the door has the proper force when it goes down, and to check this, you can use a board as an obstacle for the door. If it does not pop back up when it hits the board, you have to decrease the garage down force from the control panel of the garage door. Set the proper down force until the door pops back up when hitting an obstacle.
3. Sensors Not Working
Nearly all electric garage doors have electric eyes that are placed down on the sides. Generally, one of the sensors will have a red light, and the opposite one will have a green light. Hence, if the sensors are good, they will start flashing when you put your hand in front of them, so if your door is not operating, make sure to check the sensors first.
4. Sensors Out of Alignment
The sensors on the sides must be exactly facing one another to function properly. Otherwise, if they are not aligned, the sensor will not work at all. Thus, you can set the sensors position by adjusting the bracket on the side until you see a steady red light.
5. Check the Motor
If the garage door is not operating at all, another reason could be a problem with the motor. In this case, check the motor which pulls the garage door upwards, and if it is not working, you will need to replace it. However, it is recommend that you buy a similar motor from the garage manufacturer.
These are some common problems which you can run into and some simple adjustments that you can make to keep your garage door operating safely and properly. However, if none of these adjustments work, contact for a professional technician to adjust your garage door.
