Four Reasons Your Drain Is Slow
When your kitchen or bathroom sink starts to drain slow, it can be a downright nuisance and inconvenience. Indeed, it could also turn out to be quite frustrating to shower properly or to actually clean your bath tub, and you could find your sink taking far too long to drain itself after every use. It is easy to notice an increase in the time it takes for your sink or bathtub to drain, so in case there is you need to attend to it right away. After all, a slow drain may quickly become a clogged one, in which case it would be even more difficult to deal with.
1. Accumulation of Hair
When it comes to a bath tub, hair could be very troublesome. It is inevitable that some hair will find itself in your drain, whether you take a shower or a full bath. This is not a question of hair loss – even young people lose a few hairs while they wash it. Naturally, if you have hair loss problems you would have to be even more careful.
If you think that a few stray hairs could not possibly do any harm, think again. Hair tends to accumulate relatively quickly, and a few hairs may well end up being a hairball. The more hair gets clogged up, the more chance there is of the problem worsening. Keep in mind that prevention is always better than cure, so make sure you use a simple wire mesh hair stopper. If you use it during every bath or shower, you should not have any problems with hair clogging. In case it is too late you can remove the accumulated hair quite easily. This can be done either manually, by using your fingers, or with the help of a chemical solution.
2. Build-Up Of Soap Particles
Both a sink as well as a bath tub will inevitably face quite a lot of soap. Unfortunately, soap is also one of the main reasons behind a slow drain, since a build up of soap particles will partially block the drain. Naturally, a combination of hair and soap would be even more troublesome.
Once again, using a wire mesh filter over the drain in your sink or bath tub could greatly help in preventing an accumulation of soap. You may also consider using liquid soap rather than the traditional soap bars. This is because soap bars are more prone to cause a clogged drain due to their solid nature.
3. Pouring Grease
You should never discharge grease down a drainpipe, since grease is one of the most damaging liquids to your plumbing. In fact, when grease cools down it tends to coagulate rapidly in your pipes, resulting in a slow drain and eventually in a clogged one.
4. Other Biological Life Forms
It may come as a surprise, but your kitchen sink drain is actually a very rich environment for certain life forms. As such, if there is an accumulation of such forms of life in your pipe, it is bound to drain slower. Pouring hot water down the drain may kill the unwanted guests, although your best bet in this case is to use an appropriate liquid which can be bought from any supermarket.
Slow drains are an annoyance, but they could easily become more than just irritating if you do not act in time. Make sure you deal with a slow drain before it becomes completely clogged, so you avoid further unnecessary expenses.
