Frosted Glass Sliding Doors: Maintenance and Cleaning
Frosted glass sliding doors are a wonderful choice for the interior or exterior of your home. They are designed to give the appearance of glass but they offer privacy at the same time. They can be made with designs in the frosted glass that add to the décor of your home.
Cleaning the Glass
It is important that you keep your sliding glass doors clean. Nothing can detract from these stunning doors more than fingerprints and smudges in the glass. If they are used in the interior of your home, you should make sure that you keep fingerprints off of the glass by using a mild glass cleaner regularly.
Exterior doors may require more work to keep clean. Dirt and mud can be on the outside of the doors that will require you to hose down the glass. Make sure that you are using a mild soap on the doors and that you do not scratch the frosted areas and damage the design.
Keeping the Doors Clean
Glass doors can be beautiful in the home, but they can also be difficult to keep clean. A regular cleaning schedule will make sure that dirt and smudges are removed promptly. Encourage everyone to use the handles when opening and closing the doors to keep fingerprints to a minimum.
