Garage Foundation Repair Tips
The main purpose of garage foundation repair is to improve and ensure stability of the complete garage structure. Needless to say, it is of vital importance that the foundation should be laid properly to ensure safety, solidity and permanence to your garage for the complete lifetime of your house.
The foundation of your garage is similar to the foundation of the rest of your house. The most common danger to any garage foundation is shifting of the underneath soil. The soil or the ground can shift due to many reasons, primary due to the water content in the soil and any underground rivers deep beneath the surface of the ground. Another big risk that can damage the foundation of your garage is uneven support to the structure. Any unevenness to the support structure can cause sagging of that particular part of the garage floor, leading to major structural damage and a risk to the safety of the inhabitants of the house. Here are some tips on garage foundation repair.
Know How to Identify Signs of Damage:
Remember that sagging or leaking foundation will cause devaluation of your property. The tell tale signs of damage to the foundation of your garage include evidence of leak on the floor or the walls, cracks on the foundation walls, and un-leveling of floors. Other smaller signs can be doors or windows that used to operate properly in the past but are now sticking out, as well as any cracks on the exterior walls of the garage.
Take Care while Hiring a Repair Contractor:
Repairing the garage foundation is usually not a Do It Yourself project for amateurs. It is best that you hire a qualified professional for the work. While you can approach a contractor by looking one up in the yellow pages, it is strongly recommended that you check out some references to ensure that the contractor has a good reputation. Even if you are not strapped for money, ensure that you take a complete quotation of the work that includes material costs and labor costs.
Know the Area and the Soil Base on which Your House Has Been Built:
This pointer is of utmost importance. If you are living in an area that has extreme weather, especially cold areas, it is a good idea to invest in a professional geologist consultancy. They will help you to understand the soil freezing point. You can also hire a professional architect or a civil engineer for this information. Such professionals will also help you understand the type of soil.
Maintenance of the Repaired Foundation:
Proper maintenance of the soil around the foundation of your garage floor goes a long way in ensuring its longevity. For example, if you stay in an area that has dry summers and wet winters, watering the soil in the dry season will help maintain a stable water content in the soil.
