Gas Furnace Venting Options Explained
There are different gas furnace venting options to provide the combustion needs of  your home. Giving proper ventilation for your gas furnace is very important so that its performance and your safety will not be compromised.  3 of the common gas furnace venting options will be explained in this article to help you determine which kind is needed for your home.
Ventilation through a Window
This kind of ventilation is very easy and almost at no cost, depending where you placed your gas furnace. If a window is situated near your gas furnace, then this can serve as its ventilation. You can purposely place a window near your gas furnace to be its ventilation but this is only a temporary solution and is not always effective.
Although for places that has colder temperatures especially on winter, this can be a suitable ventilation because the cold air from the outside helps cool the heat produced by your gas furnace and keeps the whole area cold.
Ventilation through an Exhaust Fan
This is a very common way of providing ventilation for your gas furnace. It ensures that the heat expelled by the furnace is ventilated out so it doesn’t confine the hot air inside which can be a source of fire. If your gas furnace has no proper ventilation, this is a good and less expensive way on making one. It may add additional cost in your electricity bill, but it is a small price to pay in exchange of your safety in your home.
Adding an Induced Blower in Your Ventilation
Another type of ventilation to be used with an exhaust fan is an induced blower. An induced blower brings fresh air into the gas furnace to go through the process and it is the exhaust fans job to take out the hot air. This type of ventilation will greatly improve the circulation and quality of air distributed in the house.
This type of ventilation is especially helpful when your gas furnace is placed near other appliances that add up to the hot temperature of the room.  So you are not only ventilating your gas furnace but also other appliances that are not supposed to be exposed to too much heat.
It is important to choose the appropriate ventilation for your home. If the heat emitted by the gas furnace remains confined in a room, it can lead to various accidents that could have been avoided if the proper ventilation was installed in the house.
If you are unsure which ventilation best suits your gas furnace needs, you can always contact a qualified professional to make the choice for you. In that way not only does he know what kind of ventilation your house needs but also the right location where to install it. You can also install a carbon monoxide detector and a smoke alarm to determine if the emitted air of your system has been effectively put out.
