Gas to Wood Fireplace: 5 Reasons to Change
As a homeowner, you may want to consider making a switch from a gas to wood fireplace. The convenience of gas fireplaces has made them popular in many homes. They give the appearance of a true fire without most of the labor associated with a wood fireplace. Gas logs and gas inserts are used to create a convincing fireplace flame. You simply turn on the flame when need be. The convenience of creating a flame without the hassles involved with timber makes a gas fireplace attractive to many. However, the traditional wood fireplace still remains popular with many. Below are five reasons for you to change from gas to wood.
Reason #1: Natural Fireplace Experience
As much as gas will give you a flame at your convenience, it cannot match the charm of a wood fireplace. There’s nothing like a nice, crackling wood fire on a cold evening. It makes the room warm and cozy. Simply sitting at the fireplace as you hear the wood pop and crackle is a real treat. The pleasant smell of burning wood further adds to the joy of a wood fireplace. Building up a wood fire is both a rewarding and therapeutic experience. The process involved makes you appreciate the fire all the more once you’ve got it started.
Reason #2: Sustainability
Both natural gas and propane which are used to fuel gas fireplaces are fossil fuels. This isn’t a renewable source of energy. Resource depletion is always a possibility even with careful usage. Wood, however, is a renewable energy source. Careful reforestation practices can ensure that there’s a continuous supply available even as wood is consumed. If sustainable resource utilization is a concern for you, why not consider a change from gas to wood fireplace?
Reason #3: Cost
Overall, wood works out as a cheaper alternative to a gas fireplace. Simply obtain the logs and burn them. Gas can turn out to be costly especially if your fireplace s frequently used. A gas fireplace requires you to be hooked to a gas line. You also need to have the vents installed in the house. Periodic maintenance is vital as a safety measure. All these add up to make a gas fireplace more costly than wood.
Reason #4: Safety
Generally, a wood fireplace has less risk attached to it than gas. The ease with which a gas fireplace can be turned on and off should cause some concern, especially for those with young children. A fireplace holds attraction for young children. They tend to be drawn by the flames. Curiosity may drive children to venture into the fireplace and experiment at lighting. Besides, there’s always the possibility of a gas leak between the gas source and the fireplace.
Reason #5: Pollution
A wood fireplace is associated with less pollution than gas. Some emissions occur during the combustion of gas which contributes to environmental pollution. The combustion of wood doesn’t cause pollution. This makes a wood fireplace a better alternative for those with eco-friendly concerns.
