GE Security Alarm
Designed with an initial capacity of up to 8 zones and expandable to nearly 200 with some models, the benefits of a GE security alarm are self evident. Given the amount of monitoring capability, your home, business or other property will be fully protected from intrusion. With a GE wireless or hardwired security system in place in a business, tracking employee movement is possible. At home, rest assured that every entry point is equipped with a sensor, whether it's a magnetic trigger point or a motion detector.
GE Security Alarm Specifications
GE security alarms come with a base number of zones: 4, 6 or 8 depending on the system. From there, expand the system wirelessly or with hardwired modules to a maximum of 192 zones. For business use or in homes with multiple tenants, partitioning the alarm is possible with most GE security systems. X10 compatibility offered with several models lets you link the alarm with various lights and/or appliances, allowing the alarm to control them.
Alarm Components
A GE security alarm setup includes a control panel, one of a variety of touchpads, door/window sensors, motion detector, indoor siren, a metal enclosure with lock and other accessories. Expansion modules allow you to add sensors, detectors and even smoke alarms to fully monitor your home or business. With easy, menu-driven programming, configuring your GE security alarm is an uncomplicated procedure.
