General Guidelines for Resurfacing Decorative Concrete
Decorative concrete is used in a wide range of applications around the home. This type of concrete design is found in many driveways, patios, and even inside on basement floors and sunrooms. A decorative concrete design is usually done to mimic some sort of exotic stone or marble finish. Resurfacing of concrete is a project that requires a lot of time and having the right tools at your disposal. Resurfacing decorative concrete requires even more attention to detail to make sure that the project comes out right. Here are some tips to think about if you are planning to resurface a decorative concrete patio or driveway.
Is Resurfacing Right for You?
Before you get started with any type of decorative concrete resurfacing project you will have to ask yourself if the resurfacing project is right for you. Take a look at the condition of your concrete as it is now. Is there any places where the concrete is sunken in? Are there large cracks in the surface of the concrete that need to be repaired? Is there evidence of soil shifting, or eroding, under the slab? If you find any of these problems within the concrete you will need to have the concrete replaced, or repaired, before any resurfacing is done.
Clean Well before Resurfacing
Any concrete surface that is going to be resurfaced will need to be thoroughly cleaned. A power washer is a good tool to have at this point. The jet stream of the water will be able to penetrate into the grime without breaking apart the decorative concrete. Mix some cleaning solution with the water for a better cleaning job.
Repair Minor Problems First
If you find that there are some small cracks, or pieces of concrete that are crumbling along the edges, this can be repaired through the use of concrete filler. This simple product is found at most hardware stores and is easily applied through a caulking tube, or through spreading with a small trowel. Before resurfacing the decorative concrete, it is important to make sure you have a concrete slab free of damage.
Know What You Want
Many times when homeowners set out to resurface the decorative concrete on their own, they do not know what they want to replace it with. Before starting to do any work involved in resurfacing, have a plan of action in mind, and a design ready to go.
Use Concrete Safe Products
There are many products on the market today that are used for resurfacing concrete. Before choosing one to use, make sure it can be used on decorative concrete surfaces. Many of the detergents, solutions, and acids, are too harsh for surfaces such as stamped concrete, or dyed concrete. It can damage the concrete where the need for professional repair is needed.
Work Quickly and Evenly
Anytime that you are putting the finished surface onto a decorative concrete slab you will want to work fairly quickly and evenly. This will help to ensure that the entire surface of the concrete will look the same without any darker spots, or areas where the concrete dried too quickly.
