Generic and Universal Thermostat Replacement Parts
If you wish to replace your thermostat parts, you may consider purchasing generic and universal thermostat replacement parts, rather than taking the risk of purchasing an expensive part. They may also be useful if you have an older, but still worthwhile, thermostat, where the parts have long since gone out of stock, but universal thermostat replacement pieces would keep working. There are many places where you can purchase generic replacement parts, either from local suppliers, or through the World Wide Web. Looking out for generic parts, even before you need them, can help to save you money in the long-term.
Finding Universal Thermostat Parts
Thermostat parts can sometimes be more costly than purchasing an entirely new thermostat. However, if you choose not to purchase a brand name, you can find plenty of generic thermostat replacement pieces which are cost effective. You will firstly need to know what exactly you are looking for, and whether the parts will be compatible with your own particular variety of thermostat. It is helpful when shopping online to have your thermostat manual with you, so you can identify pieces which are similar to those used in your device. You should also look out for washers, mechanical pieces, and screws, which might be suited to your thermostat. If you are looking for a specific piece, perhaps to fix a broken thermostat, then find precise matches by typing the number into a search engine, as sellers will often describe their generic parts as compatible with X123 or whatever the part numbers are.
Fitting the Generic Parts
If you have found the perfect replacement parts online, then you should take care to make sure that the connections are good when installing them on your thermostat. Try using a metal file to remove lumps and makers lines which would not be on the original. You can also slightly enlarge holes in the generic parts using a file. This will help the part to fit more securely onto your thermostat. You may also need to adapt universal replacement parts to fit your device. When installing, be prepared to slightly warm any metal components to make them more flexible, and then bend with a pair of pliers, one on each side. This will help to ensure that the replacement part is not damaged when you flex it.
Buying Generic Parts Online
As with all online purchases, it makes sense to take extra care, and ensure that you are not being ripped off. Replacement parts in cars are often replicated to a poorer standard, and you should expect this when buying universal parts also. However, there are still a number of good copies of manufacturer's parts which are durable and long-lasting. Try and buy from a seller with a good record, check any comment boxes for praise or denouncement. You should also check several times that the description of the item being sold matches with that of your device, so that you will know what to expect. It is not unusual for keen buyers to purchase an item, expecting it to be exactly like the part they want to replace, only to be disappointed when the piece arrives.
