Getting Rid of Carpenter Bees: 4 Tips
Carpenter bees are most prevalent during the spring. They are so named because they create galleries in all types of wood which they use as their living nests. The bee makes its home inside wood by boring through the tree or other wooden material.
You can note their presence easily, as they tend to be active. They do not sting but can vex by the sheer amount of noise they produce. The carpenter bee resembles the bumblebee, but whereas the bumblebee has lots of hair on the abdomen with yellow markings, the carpenter bee has a predominantly black and shiny abdomen.
Carpenter bees usually love to settle around the house, under the eaves, and where cracks occur between sidings or on roofing material. You will also notice them around flowers, shrubs, trees and fence posts. They do not cause structural damage, but their presence constitutes a nuisance because of their noise and sawdust shavings that accompany their excavations. Below are tips you may find useful in getting rid of these bees.
1. Vacuuming
This is a simple yet effective strategy for eliminating carpenter bees from around your house. It is best to use a vacuum when the bee nest is still quite new. New nests are likely to have a smaller number of bees, maybe 20 to 30, which makes it easier to use a vacuum the nest.
Evening hours are most ideal for vacuuming because the bees are likely to have returned to the nest. They are also slower in their activities at this time of the day and less likely to be roused into activity when you disrupt them.
2. Using Insecticides
You can spray insecticides onto the bee nest. Most insecticides are quite effective in getting rid of the bees. You can obtain natural insecticides if you prefer not to use chemical preparations. It is best to apply insecticides early in the spring as soon as the bees manifest.
3. Trapping
You can use material such as caulk or putty to trap the bees in their galleries. Block the entrance to the bee nest with caulk or putty. The bees are unable to burrow their way through these substances. Once trapped inside, they will die eventually. You can then paint over the bee gallery entrances to achieve a neat look. Painting will also prevent new excavations from taking place. This is a simple yet effective approach that involves minimal time and money.
4. Capturing the Queen Bee
Capturing the queen bee is best achieved when the nest is new. Once you capture the single female, you can proceed to swat her. Each nest has only one female bee and several male bees. Capturing the female bee will definitely ensure that laying of eggs comes to a halt and thus restrict further reproduction of the bees.
