Glueless Bamboo Flooring: Pros and Cons
Glueless bamboo flooring is a great option for homeowners who prefer to have a floor installed without the messy job that glue often entails. The flooring is designed in such a way that it simply clicks and locks into place. It is also referred to as click-lock flooring. Although it may sound like a floating floor, the floor is securely locked in place once laid out. You needn’t worry about the floor moving or getting detached. It is both a functional and durable floor type which also lends a classy look to your home. If you’re wondering what type of bamboo floor to install, why not try the click lock floor? Below are the pros and cons.
Pros of Glueless Bamboo Flooring
Installation of the click lock floor is a fairly easy job since the procedure eliminates the need for glue. Glued floors involve much effort and time which adds to installation costs.
Floor installation for the glueless floor is a simple job you can undertake independently. No special skills or tools are required. The floor is simply locked into place without adhesives yet remains secure. The glueless bamboo floor therefore helps you save on installation costs. You can complete installation in about half the time required with glued floors. The quick turnaround time is welcome as you can complete your project and move on to engage in other activities.
No prerequisite work is required on the sub-floor when installing the bamboo floor. You needn’t worry about your existing floor being ruined during installation.
The versatility of glueless bamboo floors also adds to their benefits. It is a temporary type of floor which can easily be detached should you prefer a change in the future. If detached, you’ll find your sub-floor is good condition which helps save you on repair costs. The click lock floor actually helps you protect your original floor.
The floors also come in a wide color range. This makes it easier for you to achieve a preferred color scheme for your house.
The click lock floor also makes it easier to undertake routine maintenance work on the sub-floor when need arises. Should drainage problems arise on the sub-floor or electrical maintenance becomes necessary, it is much easier to access the sub-floor. The floor is easily detached yet remains in great shape even after removal.
Cons
Glueless bamboo floors are some of the higher priced bamboo floor types. This is partly because of the convenience attached to these floors. The price may be a deterrent.
Unfortunately, wider planks are used to manufacture glueless bamboo floors. This increases the risk of cupping due to wider exposure to moisture. Should water or liquid spill onto the floor it can easily penetrate the floorboards due to the absence of glue which acts as a barrier. This necessitates immediate mopping when spillages occur. It is best to get a moisture barrier to lay underneath the glueless floor. This would help prevent damage to the floor by moisture.
