Go Green- How Eco-Friendly Living May Save You Money Go Green- How Eco-Friendly Living May Save You Money
Consumers who want to go green find many benefits, such as; save you money in utility bills, save water and save money in gas expenses. Here are a few important considerations and benefits.
Reducing Water Consumption Can Help Consumers Go Green
Inside the home and out, consumers can do a number of things to reduce water consumption and save money. The U.S. Environmental Protection Agency (EPA) says that the average household spends as much as $500 annually on water and sewer bills. By installing more water-efficient fixtures and appliances, they can save $170 per year.
Items to consider include simple restricted nozzles non faucets, low-flow showerheads, energy-efficient dishwasher and washers, and low-flow or dual-flush toilets. The EPA recommends consumers look for the WaterSense labels on products, which means the products are 20 percent more water efficient and perform as well as conventional models.
Another consideration is a tankless hot water system. This system provides hot water on demand, instead of the conventional system which stores heated water at constant temperatures. Tankless hot water systems can recoup their initial cost in just a few years, depending on water usage.
Conserving Energy Saves Money and Helps Everyone Go Green
Green comfort living means choosing energy-efficient, EnergyStar heating and air conditioning that use less energy. This is another efficient way to save money on monthly gas and electric bills. Get in the habit of turning the temperature down at night in the winter, and pile extra blankets on the bed. During the day, wear a sweater, or layer your clothing, instead of cranking up the thermostat. In the summer, use EnergyStar fans instead of the air conditioning. Put up blackout curtains to keep heat in during the winter and heat out in the summer.
If conditions are right for appropriate amount of sunlight, consider using solar energy panels to partially power the home. Consumers who are able to go green by going off-grid will see their meter bills reduced. Solar-powered pathway and landscape lighting also saves money and is very inexpensive to purchase at any local home or garden store.
Additionally, many green guide recommendations include the use of compact fluorescent lamps (CFLs), instead of incandescent lights. This saves energy and money because the CFLs run at a cooler temperature for a longer period of time.
Go Green Outside Too
Use drip irrigation and new weather-based irrigation controllers to avoid wasting water. Avoid watering at peak periods and use mulch around plants, trees and shrubs to conserve water and keep them healthy. Consider planting drought-tolerant varieties and using decorative edging and trim – rocks, boulders, pavers, etc., instead of living plants that need water.
Don’t Forget to Go Green in the Car
Consider downsizing, or getting rid of that old clunker for a new, more fuel-efficient model. Newer cars are built with better gas efficiency levels that save gas, maintenance costs and insurance. Also, use the air conditioner on low when doing highway speeds, but open the windows when traveling by streets, in town. This can also help you save money on gas consumption.
Other driving tips include: combine errands into a single trip, no more jack-rabbit starts, ease off the heavy braking, and maintain a steady pace on the gas pedal. Use cruise control when appropriate on the highway.
Remember, to go green means making conscious decisions to implement more eco-friendly techniques into daily living. By doing so, consumers may be also pleasantly surprised at how the savings add up.
