Granite Backsplash: Pros and Cons
Installing a granite backsplash is very popular choice for many different types of kitchens. Granite presents you with several benefits as compared to other backsplash materials. Here are a few pros and cons of granite backsplashes.
Pros
- Looks: Granite provides you a surface that looks like nothing else. Granite is one of the most sought-after natural stone products in the world. Many people use it for countertops, flooring, and other applications. You can get it in many different colors and looks as well.
- Strength: Since granite is a natural stone product, it is very durable and strong. Once it is installed, it should hold up to a lot of wear and tear.
Cons
- Can stain: Granite has been known to stain under certain conditions. If you allow certain foods or liquids to get on the surface and do not clean it off quickly, it could potentially stain or etch into the top layer.
- Requires sealing: When you get a granite backsplash, you will have to seal it periodically. Since it can soak up liquids, you will have to seal it with the proper granite sealer. Once the granite is sealed, you will also have to reapply the sealer every 1 to 3 years as well.
