Green Homes- How to Install Recirculating Water Pump Green Homes- How to Install Recirculating Water Pump
Wrenches
Hot-water recirculating pump
The control box for the pump
All required piping and tubing (this is normally included with the unit)
In designing today's newer green homes, architects and contractors are calling for the use of hot-water recirculating pumps to make homes more energy efficient and reduce the waste of water. Recirculating pumps use less water than normal hot water heaters alone and allow for a much lower energy usage. Moreover, installing a hot-water recirculating pop is much easier than you might think, and can be completed in just a few hours. Here is a handy step-by-step guide to help you install a hot-water recirculating pump:
Step 1 - Choose the Proper Location
First, you'll need to find the appropriate spot to install your new hot-water recirculating pump. The best place to install the pump is near the fixture that his fatherest away from your hot water heater. This fixture may be a toilet, sink or shower - it really doesn't matter what type of fixture it is. Installing the pump at the farthest fixture will help minimize energy waste and help save money on your electrical bill.
Step 2 - Cut the Water Supply
Next, you'll need to make sure you shut off the main water supply valves that run into your home. Also, you will need to make sure that you shut off the main water supply vows at the fixture nearest to the point you want to install the hot-water recirculating pump. Make sure that the valves are turned off completely and that no more water is entering the piping system of the fixture.
Step 3 - Attach the Recirculating Pump
Now, you'll need to connect the recirculating pump to the fixture you’ve chosen name by using the stainless steel tubing or copper piping that is supplied with your hot-water recirculating pump. The lines are usually connected to the fixture with a simple washer connection that can be screwed on by hand and then tightened even more with a wrench.
Step 4 - Choose a Location for the Control Box
Next, you'll need to choose a location for the control box of the hot-water recirculating pump. You should choose a place that is close to the pump itself; however, you need to choose a place that is up and away from an area that may become wet.
Step 5 - Install the Control Box
Follow the manufacturer's directions to install the control box and hook it up to your hot-water recirculating pump.
Step 6 - Turn the Water Back On
Finally, turn back on the water at your fixture and your main water supply from the outside. The unit is now ready to be tested; however, if you have followed the manufacturer's directions everything should be fine.
You should always choose a hot-water recirculating pump that has a control box with a timer. These types of control boxes allow you to set the units to operate during hours which you may be awake and remain off during the night. A timer can help you save a lot of money and energy costs while still providing hot-water when you need it.
