Guide to Glass Stair Building for the First Timer
If you are unfamiliar with glass stair building, but would like to learn how to install a breathtaking glass staircase in your home, you should know that the installation of these types of stairs is not for all DIY enthusiasts. Installing glass stairs in your home requires a lot planning and knowledge on how to choose the correct types of materials. Although glass stairs are beautiful addition to any home, they can be dangerous is not properly built and installed. Therefore, this article will provide you with information on how to properly go about planning and executing the installation of glass stairs in your home.
Avoid Choosing the Glass Yourself
Whenever considering glass to be used as steps in your glass staircase, you'll probably be tempted to a choose a design that your find attractive and appealing. Although everyone wants to make their home as beautiful and inviting as possible, this is not always the best approach for choosing glass to be used in a glass stairwell.
In fact, you should avoid choosing the glass and support system for the stairs separately. Instead, you should find manufacturers of glass stair kits. Reparable manufacturers of these kits have spent a lot of time in developing and manufacturing glass that is safe for use as stairs. There are several attractive design types available, and you should be able to find one that matches well with the interior of your home. However, when choosing glass for your stairs, always consult with a professional or expert before making a decision.
Glass Stairs Have Low Tolerances for Error
Regardless of the quality of the materials used in glass stairs, the steps are still made of glass and can possibly be broken (if not properly installed). Therefore, you should always understand that the installation of glass stairs in your home means that there are very low tolerances for error or mistake. You will have to follow installation instructions exactly when installing the hand and support rails that will be used to hold the glass steps in place.
Proper Support Installation is Essential
When installing the support structure for glass stairs, it is imperative that you be familiar with proper fastening techniques that will be used to secure runners and railings to the wall and the glass steps. Also, you should be adept in using high quality silicone-based caulking and other adhesives to adhere the glass to the runners. So, even though it means wasting a few tubes of caulk a number of fasteners, you should always practice using these adhesives or fasteners before you attempt to perform the task on your glass stairs.
Pay Attention to Detail
The installation of glass stairs in your home requires meticulous attention to detail. So, if you're the type of DIY builder that is lackadaisical in his/her approach to following directions, or if you are the type of person that sometimes skips a few steps, the installation of glass stairs is not for you.
Because the installation of glass stairs requires that the installation of the stairwell be as safe as possible, you will need to follow instructions exactly. If you feel you may not be able to do this, it is better if you have a professional install the glass stairs for you.
