Hanging Flexible Drywall Hanging Flexible Drywall
Flexible drywall
Saw
Drywall screw gun
Drywall screws
Stud finder
Hanging drywall is a simple project to do, and hanging flexible drywall is even easier. if this is something that you are planning to take on in the near future whether you are moving to another home or redoing your current one, there are a few things that you will want to consider. Here is a quick guide to help you through the process.
Step 1 - Locate Studs
Begin by locating the studs using a stud finder. It is important to do this before you begin so that you know where they are going to be when you start nailing.
Step 2 - Cut
Use a saw to cut the drywall to the size that you need. you want to work with manageable pieces, but you also want to use the biggest ones that you can.
Step 3 - Apply Drywall
When applying the drywall you want to start from the top and work your way down. You will want to have someone help you through this process and one person can hold the drywall up while the other person goes through and nails or screws it in with a screw gun on the studs.
