Homemade Stainless Steel Scratch Remover
You can create a stainless steel scratch remover just from common items that you have around your house. A lot of people opt to use stainless steel appliances because they are very posh to look at and easier to maintain compared to others. But this does not mean that it is not susceptible to the usual wearing out that metallic items undergo. As the name suggests, stainless steel does not stain that much but the problem that you will have with stainless steel is that they are easy to get scratched.
Try Vegetable Oil
The first option that you have is to use vegetable oil on as your stainless steel scratch remover. This is something that most of us can easily find in our kitchen cupboards. Dab some of the oil onto the scratch and use a paper towel to wipe it clean.
Use a Scouring Pad
If the vegetable oil is not enough to remove the scratch, you can use a soft scouring pad that is non-abrasive and can prevent more scratches from getting on the steel. The smaller scratches will probably disappear with this method. If the scratch is too big, you can move on to use a commercial remover.
