Horse Care: Making a Cheap Portable Corral Horse Care: Making a Cheap Portable Corral
Horse Panels
Post Hole Diggers
Concrete
Drill
Plywood
Panel Pins
Bailing Wire
T Posts
horse portable corral is a great way for you to keep your horses contained no matter where they are. There is a way to make your own to save you quite a bit of money.
Step 1 – T Posts
Begin by driving T posts into the ground where you wish to have your portable corral. Once they are in the ground you will need to attach them to your panels for stability.
Step 2  Panels
Stand the panels up and use your panel pins to connect them. Whenever the pins are put into place you will need to use bailing wire to secure the pins.
Step 3 – Wire
Using one wire that will go in the middle will be fine for a portable corral. Any extra wire that you may have will need to be completely cut off, as it could be dangerous to the horse.
Step 4 – Wiring Buckets
A temporary corral will be able to use either plywood or wiring to attach buckets to the panels. Wiring buckets is much easier to do.
