Hot Topics: Oops, Drilled Through a Vent Pipe
Here on DoItYourself.com we enjoy providing a place where home improvement novices and experts can come together to share ideas and advice. Inside our Forums, users can browse threads to see what exchanges are taking place on a topic of interest or start their own dialogue by posting something for the community to take part in. With over 250,000 members and counting, this resource is quite active, so each week we highlight one of the conversations that may just help you with that next DIY project.
Even with a stud finder, you can’t always tell what’s behind your drywall. Better to hit a dryer vent than a gas line, but you still have to fix it. The OP seems reluctant to cut out more drywall, but regardless of which of the Forum’s solution he goes with, he’s going to have to.
Original Post: Drilled into dryer exhaust pipe - seeking advice on how to fix
theron_day Member
Hello, this is my first post and feel I like a complete idiot and looking for some advice. Any input is greatly appreciated.
I recently was trying to mount a pot rack/hanger in the kitchen (used a stud finder) and mistakenly drilled into the dryer exhaust pipe located behind the drywall. I was able to determine that it was the dryer exhaust - it was emitting a tiny amount of air when the dryer located directly on the floor below was on. I turned it off immediately, being aware of the carbon monoxide emission and am currently not using the dryer until I can resolve this issue.
Any input appreciated on how to correct? I cut about a 1x1-inch area out of drywall around the drilled hole.
Highlights from the Thread
PJmax Forum Topic Moderator
Welcome to the forums.
You could use a piece of foil tape to reseal that if you can get it in there. Otherwise use a small amount of high heat silicone like that which would be used for a car. There is very low pressure there. It won't take much to seal it.
theron_day Member
Thank you PJmax. I don’t think I can get the foil tape around the exhaust pipe (unless I cut the drywall more). So maybe like you said the high heat silicone… like this?
Shop IMPERIAL Silicone Sealant at Lowes.com
pugsl Forum Topic Moderator
Carbon monoxide emission is not a problem with a dryer vent. Foil tape is the best to use if can get in.
theron_day Member
Thanks pugsi, I will definitely look into that and see about the foil tape if I can get into enough contact area.... Thanks to both comments so far!!!! Much appreciated.
lawrosa Super Moderator
“Carbon monoxide emission is not a problem with dryer vent.”
A gas dryer yes... Electric no...
Yes a small square of metal tape would be best... Make sure it’s the real metal tape and not the plastic backed fake stuff that will melt... read the temp ratings on the label to be sure... I believe it says 600F or something in that area.
theron_day Member
My fault, it's an electric dryer.
Fixing this leads to the discovery of a much larger venting problem. Read more at: //www.doityourself.com/forum/ducting-air-circulation-ventilation-systems/506698-drilled-into-dryer-exhaust-pipe-seeking-advice-how-fix.html#ixzz2ggFvtH9p
