Hot Topics: Restoring the Finish of a Teak Dining Table
Here at DoItYourself.com we enjoy providing a place where home improvement novices and experts can come together to share ideas and advice. Inside our Forums, users can browse threads to see what exchanges are taking place on a topic of interest or start their own dialogue by posting something for the community to take part in. With over 250,000 members and counting, this resource is quite active so each week we highlight one of the conversations that may just help you with that next DIY project.
Original Post: Restoring the Finish of a Teak Dining Table
Graham Dollow Member
Hi
I have an old dining table I'd like to restore, the top is in pretty bad condition, so I was wondering if anyone has advice on how to get a decent finish back to the table.
Thanks
Highlights from the Thread
Chandler Forum Topic Moderator
Welcome to the forums! Yeah it's bad. A random orbit sander with 220 grit paper will help smooth it out, but you also have to remove all the original finish, so something like Formby's refinishing may help get all the previous finish off of it, then sand, stain and re finish.
Our paint guy will be along shortly, so hang in there for his opinion.
Furd Member
Once you get the table clean I suggest using teak oil as a finish. It will take a couple of days to dry thoroughly but will be easy to re-finish as necessary.
Joecaption Member
As bad as that is 220 grit will just load up.
If it was mine I start with 60 grit and work my way down.
100 % sure that's Teak? Sure looks more like oak to me.
I am assuming it's teak by the colour of the rest of the table, such as the under side and the legs. Once I take it back to the bare wood I will know for definte.
Thanks for the responses. I will start it next weekend as I need to get some sandpaper, sanding block, and teak oil.
Furd Member
Teak does have a number of different grain patterns so while it MIGHT be oak it is impossible to say from this small picture.
Graham, after cleaning it up take a larger picture and post it and we may be able to tell positively if it is teak. I'd be wary of using teak oil on anything but teak.
Marksr Member
Me too! Let us know or post a pic after you get it stripped down.
Joecaption Member
I'd be using a random orbital sander.
It would take days to hand sand a whole table by hand.
I tried sanding the table, and I was a bit too vigerous, not realising that it was a teak veneer, so I sanded it down to the chipboard. So is there anything I can do to rescue it.
sanded teak table
Marksr Member
Once you go thru the veneer you have 2 choices; replace the veneer or use a filler, primer and paint L
Read more at: //www.doityourself.com/forum/furniture-wood-cabinetry-finishing/549832-restoring-finish-teak-dining-table.html
Topics:
