Hot Topics: Should I Remove Vinyl and Underlayment before Installing Tile?
Lead Image for Hot Topics: Should I Remove Vinyl and Underlayment before Installing Tile?
Here at DoItYourself.com we enjoy providing a place where home improvement novices and experts can come together to share ideas and advice. Inside our Forums, users can browse threads to see what exchanges are taking place on a topic of interest or start their own dialogue by posting something for the community to take part in. With over 250,000 members and counting, this resource is quite active so each week we highlight one of the conversations that may just help you with that next DIY project.
Original Post: Remove vinyl and underlayment before installing tile?
apsuhead Member
I am removing vinyl from our kitchen and bathrooms and installing backer board/ceramic tile. In our last home, I just removed the vinyl and my tile guy did the rest. I am going to attempt to tile this myself. My new house has a thin underlayment over the subfloor and under the vinyl. Should I remove this underlayment before putting down the backer board? Not sure how difficult this would be? I just don't want the new tile floor to be so much higher at the transitions to laminate hardwood, and it will also make the counters seem shorter. Any advice? Thanks!
Highlights from the Thread
czizzi Forum Topic Moderator
Will need a little additional information. Just because the house is 10 years old does not mean it meets specs for a tile installation. When the house was built, it was spec'd for vinyl, not tile. Tile needs a much stiffer floor (even stiffer if using natural stone). So for peace of mind, please provide the size of the joists, the distance between joists, the length of the unsupported span of those joists, and if you happen to see markings, the species/grade of the joists as well. We will also need to know what kind and thickness of plywood/OSB is currently down under the 1/4" underlayment. Joe is correct, the 1/4" underlayment and the vinyl needs to come up.
One final observation - the height requirements of the tile have no relation to the current height of the laminate. They are two different floor systems and have completely different requirements. If there is a difference (and most likely there will be) a reducer, t-molding or other transition piece will be used.
apsuhead Member
I am just in the planning stages. I will check out the flooring substructure next. I have enough tile to do the entire house (got it super cheap on clearance and had 20% promo code = $.25 sq ft). i have 2 lots - one lot will be used in the bathrooms while the other in the big kitchen area. I will start in the bathroom and see how it goes.
All sorts of fun angles to play with in your bathroom. A wet saw is almost mandatory. Use some scrap tile cut perfectly in half as a template to mark you new rows to help maintain your "brick" pattern stagger. Just a pencil tick to help keep your half tile seams lined up. With luck, your walls and tub are at perfect 45 degrees relative to the direction of the floor. I use a speed square to transfer the angle onto the tile.
apsuhead Member
Any tips on removing staples? I removed the carpet staples from our 3 sets of stairs with flat head screwdriver and pliers, it wasn't fun. Someone suggested a cotter pin puller so I might get a set a set of those. My kitchen, half-bath, laundry room, eat-in-kitchen, stair landing area is big and full of doorways and angled cuts. Est 421 sq ft.
Floor scraper held low to the ground will shear the staples off or pull them out.
Unless you are talking about staples in carpet pad. Then you have to pull them.
Read more at: //www.doityourself.com/forum/wall-flooring-indoor-tiling/548695-remove-vinyl-underlayment-before-installing-tile.html
