Hot Water Heater Prices
When it comes to hot water heater prices there are plenty of different considerations to think about. Pricing a hot water heater will depend on several factors including the size of the tank. Buying a hot water heater is something that many homeowners must do when buying an old house, or if they have had one for over 10 years. If you are in the market for a new heater, here are some hot water heater prices, and factors to think about.
Size of Water Heater
One of the determining factors in the price of a hot water heater is the size of the tank. Smaller tanks are not going to cost as much as larger ones. For instance, a 40-gallon Bradford gas hot water heater will cost $800 The same manufacturer has a 60-gallon tank for $1,500. The different manufacturers like GE, Kenmore, and Whirlpool will also vary their prices according to sizes as well. A 40-gallon tank is adequate for a single home, but if you have a large family, you may want to look at the larger 60-gallon hot water heater.
Features Dictate Higher Prices
When it comes to hot water heaters, price does make a difference in quality and features. If you are looking at purchasing an inexpensive hot water heater, you may find that it is not worth the savings if you have problems, or the water does not get hot enough. One of the biggest features of a hot water heater is the amount of hot water per hour you will receive. This can range from 70 to 100 gallons depending on the manufacturer.
Different Models, Different Prices
When you talk about hot water heater prices you cannot discount the fact that there are different manufacturers that have models on the market. For a good view of the different options, you should do some shopping around. Look at the different models, and options on the market before you make a decision on the first one you see.
Whirlpool Prices
Whirlpool has been a leader in the hot water heater market for several years. This is because of the product that they produce. The 40-gallon gas hot water heater is loaded with plenty of features and produces hot water at a rate of 40,000 BTU per hour. The price comes in at $750 and is a tremendous value. A larger 190,000 BTU heater that produces up to 200 gallons of hot water per hour is available that costs around $1,500.
Bradford Prices
As stated already, the Bradford 40-gallon hot water heater will cost around $800. This unit is a marvel of safety features and care-free maintenance. There is a lot of technology built into this heater that reduces chance of fire, does not need to be drained, and delivers up to 92 gallons of water per hour.
Kenmore Prices
Another leader in hot water heaters is Kenmore. This company has taken their own brand of technology to their hot water heater and has a 40-gallon gas water heater for less than $700. Producing up to 71 gallons of hot water per hour, this hot water heater can keep a small family supplied with hot water without worry of running out.
