House Construction Methods That Save Time House Construction Methods That Save Time
Choose house construction that are safe, inexpensive and time-efficient.
Common Construction Methods
A 2-by-4 stud wall is the most common and simplest method of construction, which is the most convenient option for people looking out for quicker methods. This type of construction is not only economical, but it provides solid support and strength to the structure.
A drawback of 2-by-4 stud walls is that they may not provide adequate space for insulation. In such cases, a 2-by-6 stud wall can be a better option as it provides additional space, though it can be a bit more expensive.
If you prefer high levels of insulation, then Insulated Concrete Forms (ICF) can be a good choice as they are more durable and provide greater strength. Construction with ICF is suitable for areas that experience extreme weather and changing climate conditions such as high fluctuations in temperature. If you have a planned budget and a little more money to spend, then this kind of construction may be more right for you.
Logs and timber have been used to build homes for many centuries. While construction with these materials is relatively easy, this method may have more maintenance problems down the road. Modern composites of wood plus other fibers (like plastic) can provide a more durable alternative.
Steel Stud Construction
Commercial builders adapt this construction method due to the superior strength and durability offered by steel. However, the method of construction used in wood construction and steel frame construction remains the same.
Pre-Fabricated Homes
Pre-fabricated homes can be a great option if you want to ensure speedy construction of your home at an affordable cost. This kind of construction method has gained popularity recently due to the ease of construction and minimal effort involved in the process. Pre-fabricated homes can sometimes be called by other names, like panelized homes. The process of construction is simplified as  certain sections of the walls are delivered to the construction sites already assembled.
Modular homes are another kind of pre-fabricated homes that are almost completed before delivery to the construction site. Most of these modular homes come as large sections of 2,3 or 4 depending on the requirement of home construction.
There are also factory-framed homes, which are made according to unique specifications and can be assembled at the construction site.
