How a Leaky Faucet Runs Your Wallet Dry
A leaky faucet can waste valuable natural resources and even run your wallet dry. A faucet that leaks constantly can lead to several other problems that can cost a lot of money in repairs or replacements.
Constant Drips
A faucet can leak through the head itself. This type of leak is the easiest to identify, as it leads to constant dripping or leaking.
A faucet may also leak internally. You may not notice this type of leak until you spot water stains on the ceiling underneath a bathroom or get an unexpectedly high water bill.
Unnecessarily High Water Bills
When a faucet leaks, it not only wastes valuable water, but can also run up your utilities bill. It is estimated that a leaking faucet can waste anywhere from 10 to 20 gallons of water per day. That could add up to over 100 gallons in a week that you are not using.
Replacing Sinks
When your faucet leaks for long periods of time, it can cause a brown stain on the bottom of the sink bowl. This stain is caused by the minerals and chemicals in the water and can be very hard to remove. It can also cause the sink to deteriorate over time, which will eventually call for you to replace the entire bowl.
Costly Repairs to Floors or Ceilings
Not all leaks come out the faucet's spout. Some faucets can leak from underneath the faucet base. This is caused by a loose-fitting or failed gasket.
When water continues to run down, it will cause damage to the floor covering and wood. If left untreated, the water will begin to settle on the ceiling of the room below the leak.
Removing and replacing the damaged floor and ceiling areas can be costly. Depending on the severity of the leak, you can be looking at thousands of dollars in repairs.
Stop Leaks Immediately
If you have been living with a constant drip in your faucet or have noticed an increase in your water bill, then you should look into getting the leaky faucet repaired. If you ignore problems, you will be sending your money down the drain as the water continues to add up unnecessary costs.
